Minor problems with 2001 Prado 50th Anniversary.
Hi everyone. My name's Nik, I live on NSW mid north coast.
I am looking at buying a 2001 Toyota Prado 50th Anniversary. At this stage, I only know f 2 faults / problems with this car:
1: The door remote is long lost. Can these be replaced easily? I see that you can buy them on Amazon, but can you code them without the original? The cars manual also has the key number if it's required?
2: The second fuel tank does not work. Apparently, if you switch over to the spare, the vehicle stops. In fact, the current owner uses the second tank switch as a Kill switch!
Is this a common, easily fixed problem?
As far as I've seen so far, the vehicle is in excellent condition otherwise.
