Common issues, Prado 90 Series
Toyota Prado 90 Series "Mighty 90s"
COMMON ISSUES
Overheating
Common causes for Prado overheating is an old radiator cap (not holding pressure), radiator itself (blocked or not holding pressure - replace every 200,000km/10 years), thermostat malfunctioning, and in some cases the viscous coupling fan engaging/disengaging incorrectly..
Buying advice / common failing and worn items are:
* Front upper/lower ball joints: Not expensive to replace but if left to fail, quite catastrophic and dangerous.
* All other ball joints: tie rod ends, sway bar links. Cheap/easy to replace.
* Most steering racks are worn by now and so are the reconditioned ones. Brand new Toyota is around $2000 or Chinese made $300-1000.
* Radiator, typical aluminium/plastic type has limited life, expect 10yr/200,000
* The v6 needs timing belt service every 150,000.
* When replacing front lower control arm bushings, be prepared to replace the cam adjustment components as well. Depends on the vehicles life - evidence of rust will suggest it'll be difficult to remove them - in some cases cutting is required!
